Sep 9, 2013 5:52 PM UTC
Creo 2 does not open or run
I have just installed Creo 2 and I cannot get it running at all. Specifically, clicking shortcut icons or windows start menu icons does nothing, the only confirmation that I get from my computer that i clicked those icons is that I get a little loading circle by my pointer for about a second and thats it. Nothing opens, no apps launch, no processes or services lunch, nothing. I have triend reinstalling and I have tried updating my graphics driver and neither has helped.
Thank you.
    Answer
    Oct 7, 2013 3:32 PM UTC
    I suspect that your installation is not complete. This can happen when using the web installer or when anti-virus and firewall protection is not disabled during the installation.
    For the M070 build of Creo 2.0, the size of the folders at C:\Program Files\PTC\Creo 2.0 should be close to the following:
    • Common Files ~ 2.75 GB (16,017 Files, 665 Folders)
    • Parametric ~ 121 MB (211 Files, 47 Folders)
    If your folders are smaller, I would suggest you uninstall and then reinstall using the full DVD download.
    Adam
    Sep 9, 2013 5:56 PM UTC
    Hi Ido,
    For Academic support, please see the PTC Academic Support forum. If you are unable to find a solution to your issue there, please submit an Academic Support Request.
    Chris
    Oct 7, 2013 8:09 AM UTC
    I have same question with him
    Answer
    Adam
