CREO 3.0 instalize problem
- 3 replies
- 3007 views
- Translate All
Hi!
When I started to install CREO 3.0 student version, it is started, but only one of the files was installed. When I click to the small 'i' it said the next:
Unsuccessful
=== Verbose logging started: 2015.09.30. 22:49:40 Build type: SHIP UNICODE 5.00.7601.00 Calling process: 😧 creo2===
MSI (c) (C4:AC) [22:49:40:243]: Resetting cached policy values
MSI (c) (C4:AC) [22:49:40:243]: Machine policy value 'Debug' is 0
MSI (c) (C4:AC) [22:49:40:243]: ******* RunEngine:
******* Product: 😧 creo2
******* Action:
******* CommandLine: **********
MSI (c) (C4:AC) [22:49:40:243]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (C4:AC) [22:49:40:243]: Grabbed execution mutex.
MSI (c) (C4:AC) [22:49:41:072]: Cloaking enabled.
MSI (c) (C4:AC) [22:49:41:072]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (C4:AC) [22:49:41:103]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (2C:D0) [22:49:41:135]: Running installation inside multi-package transaction 😧 creo2
MSI (s) (2C:D0) [22:49:41:135]: Grabbed execution mutex.
MSI (s) (2C:EC) [22:49:41:135]: Resetting cached policy values
MSI (s) (2C:EC) [22:49:41:135]: Machine policy value 'Debug' is 0
MSI (s) (2C:EC) [22:49:41:135]: ******* RunEngine:
******* Action:
MSI (s) (2C:EC) [22:49:41:166]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (2C:EC) [22:49:41:197]: SRSetRestorePoint skipped for this transaction.
MSI (s) (2C:EC) [22:49:41:197]: Note: 1: 1402 2: HKEY_CURRENT_USER3: 2
MSI (s) (2C:EC) [22:49:41:197]: MainEngineThread is returning 2
MSI (s) (2C:D0) [22:49:41:197]: No System Restore sequence number for this installation.
MSI (s) (2C:D0) [22:49:41:197]: User policy value 'DisableRollback' is 0
MSI (s) (2C:D0) [22:49:41:197]: Machine policy value 'DisableRollback' is 0
MSI (s) (2C:D0) [22:49:41:244]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (2C:D0) [22:49:41:244]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE3: 2
MSI (s) (2C:D0) [22:49:41:244]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (2C:D0) [22:49:41:244]: Restoring environment variables
MSI (c) (C4:AC) [22:49:41:244]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (C4:AC) [22:49:41:244]: MainEngineThread is returning 2
=== Verbose logging stopped: 2015.09.30. 22:49:41 ===
WHAT IS THE PROBLEM? It makes me crazy...
I enclosed a picture about that. Please help me, I do everything I could, but it doesn't work -_________-
