May 31, 2017 5:03 PM UTC
Creo 3.0 M110 Student Edition License Issue
Hello everyone,
For some reason when I go to enter the license code it always fails.  I even tried using the relicense instructions and it still fails.  When I went to open Creo it gave me an error which I have taken a snapshot of and attached.  This is the current code that I am using- BK400407EDSTUDENTUNICL. Thank you for your help.
Tyler
    Jun 1, 2017 6:06 AM UTC
    1.]
    C:\ProgramData\PTC\Licensing\BK390206EDSTUDENTUNICL_Iicense.dat file contains Creo Parametric 2.0 license (Version 33.0).
    2.]
    Look into C:\ProgramData\PTC\Licensing directory. Is there any other license file ?
    If BK400407EDSTUDENTUNICL license file exists, then you can modify parametric.psf in Creo 3.0 installation to link it to this license file.
    3.]
    If C:\ProgramData\PTC\Licensing directory contains BK390206EDSTUDENTUNICL_Iicense.dat file, only then >>>
    • move BK390206EDSTUDENTUNICL_Iicense.dat file into other directory (e.g. C:\Users\youraccount\Documents)
      • this step will hide license file for relicensing procedure
    • run relicensing
    4.]
    Did you receive BK400407EDSTUDENTUNICL license file via email ?
    MH
    Jun 1, 2017 1:31 PM UTC
    Hello Hanak,
    I have the same problem as Tyler. I did all steps as you said.
    To Step 2: In C:\ProgramData\PTC\Licensing are both license BK390206EDSTUDENTUNICL_Iicense.dat and BK400407EDSTUDENTUNICL therefore I moved the first license to my account as you said in step3.
    But the Problem is the current licenseBK400407EDSTUDENTUNICL is expired as you can see in the following screen shot.
    Is there any new licensecode for Creo 3.0 M110 and where can I find this one?
    Jun 2, 2017 5:27 AM UTC
    I guess that C:\ProgramData\PTC\Licensing must be empty (no files save in it), if you want to apply BK400407EDSTUDENTUNICL product code and get new license file for next one-year period.
    MH
