Nov 18, 2014 5:22 PM UTC
Creo 3 Crashes
Hi.
I have a heavy problem with Creo3.
When i create a assembly group, place the first part, it's all ok, but when i add a 2nd, open the place dialog, turn or zoom the whole thing, it crashes my video driver and Creo hangs up.
The same, when i use the mini window with the 2nd part..
It's possible to open an already created assembly with more than 2 parts, turn it arround, zoom or whatever, no problems, till i want to add a new part, then -> Creo hangs up.
It reloads my video card driver, but in the Creo Window "place" is shows up "no Responding".
All works fine till now, exept this part.
So, what can i do?
Rgds.
System: Win7 x64
Video Card: Radeon HD4290
    Nov 18, 2014 7:45 PM UTC
    Hi Daniel,
    Have you tried to reload your graphics driver? If you update it, that could possibly resolve the issue.
    If not, please let me know and there are a few other fixes you can try.
    SutoSa1-VisitorAuthor
    Nov 19, 2014 9:10 PM UTC
    Hi
    I think, i found the problem.
    I've installed Creo 2 with Startup Tools from Inneo, which changed the config.pro and Creo3 used this config file.
    After replacing them, it seems, that it works again.
    Nov 25, 2014 7:15 PM UTC
    That's great information, i'll take a note of it. Thanks!
