Creo 4.0 Academic doesn't start on win10.
  • December 29, 2017
  • 13 replies
  • 8949 views
Hi all,
My ptc creo parametric 4.0 doesn't start. I checked my graphic driver, i tried to reinstall 2 times the program but it doesn't fix it.
I tried to start with parametric.exe and .bat, also on the windows command prompt. Same problem.
No errors shown.
I also tried to disable windows defender and tried to start ptc as administrator..nothing happened.
Someone can help me?
  1. remove all license files from C:\ProgramData\PTC\Licensing directory
  2. uninstall all pieces of Creo 4.0
  3. launch setup.exe and install Creo 4.0 once again
  4. use one of following Product codes
K-12       students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
polibenex1-VisitorAuthor
Just did it, same issue.
I used the university code you wrote.
when I tested BK410705EDSTUDENTUNICL product code on 28-August-2017, I received license file named
BK410705EDSTUDENTUNICL_license.dat
containing following line:
INCREMENT CREOPMA_Student3 ptc_d 35.0 29-aug-2018 uncounted \
License name CREOPMA_Student3 is strange, but 35.0 code means that the license can be used to run Creo Parametric 4.0.
