Creo 4.0. Slowing entire PC
I installed creo 4.0. M080 Student license, some time ago (autumn 2019) and it worked perfectly. To day I wanted to work and creo gets suddenly extremely slow. The graphics is okay but  menus to open other parts or filling dimensions is incredibly slow rendering the program almost unusable, what´s worse it seems to be "infecting" my windows and suddenly my entire PC is slow as hell and I have to restart. Other programs run fine. I tried new graphics driver (two actually) neither made any difference.
My specs:
Win 10
Asus Laptop UX310UQ
i5-6200U
GTX 940M
8gb ram
I have creo on standart HDD (due to lack of space on SSD) but it seems to be running ok
Thank you
Please make sure that you are using the graphical card and not the on-board one. It may happen mainly if the graphical card is used for something else or if the default one changed.
If this is not the case, you will need to  right-click on the Creo Parametric shortcut on the desktop and go to properties. Add space after the existing target path and then -g:win32_gdi. Click on apply and run the Creo.
Alex
My specs:
Win 10
Asus Laptop UX310UQ
i5-6200U
GTX 940M
8gb ram
Thank you
please apply  -g:win32_gdi option temporarily. If Creo's response speeds up then the problem is related to graphic card drivers. I suggest you to install graphic card drivers release in autumn 2019 or earlier. Current drivers may not solve the problem.
Mikulas1-VisitorAuthor
sorry for the delay in answer. It seems to be working now for some reason do not know why maybe the new gpu driver evethough it didn´t seems to be working maybe some windows update?
Thank you for your answers anyway , should the problem re-occur I will try your advices...
