8-Gravel
January 23, 2018
Creo 4 family tree
hi everyone, I'm trying to add family table in assembly. It's a series of cylinder-style assemblies. when I add TRANSLATION1_MAXIMUM_LIMIT:CONN_4 as new column, and input values with "Open in Excel", and save, the values are not showing under the TRANSLATION column i created. Instead it shows only *.
Even when i just modify family table other columns like COMMON NAME with "Open in Excel", without touching TRANSLATION column, the values under TRANSLATION column will disappear.
is there anyway to avoid this? I really don't want to retype hundreds of value again and again.....
please upload data for testing  purposes.
gchen-28-GravelAuthor
8-Gravel
January 24, 2018
It's like if you open the assembly family table with"open in Excel", and click save in excel and come back to family table, the values under TRANSLATION column will disappear
8-Gravel
January 24, 2018
sample assembly, files attached
