Creo 4 M060 stops responding
We recently updated from Creo 3 to 4. While Creo 3 worked like a charm (and still does), Creo 4 started acting up after a couple of days and it now becomes unresponsive after just a few modeling steps. That's the same issue on Windows 7 and 10 workstations, the driver for the graphic adapter are up-to-date (NVIDIA Quadro). All config options were deactivated. Any suggestion is welcome.
Matthias
to test whether the problem is related to graphic card drivers, please add following option to config.pro file
graphics  win32_gdi
matschi1-VisitorAuthor
Hi Martin,
I checked this already. It's definitely not the graphic card driver.
Any other idea? Did anything change between Creo 3 and 4 how it deals with firewalls? What I mean is- is there an ongoing communication between the license server and local machines?
Matthias
Any other idea? ... try different Mxxx. Our customers use Creo 4.0 M040. I skipped M050 and M060.
