Creo 4 on Windows 10
After installing Creo 4 on Windows 10 Pro and after Windows 10 update to version 1709, Creo 4 is very unstable and crashes everytime. Problem I noticed is the highlighting of entities. It takes to long and after a very short time the 3D work area starts refreshing line-by-line and Creo crashes. Does anyone know to fix this?
Please submit your request in "Academic Support Request" form (here you can choose Creo 3.0 and explain that the issue is with Creo 4.0): Academic Case Logger
That sounds like a video driver issue to me, check your video card driver is up to date.  It works perfectly on 3 test machines for me.  Schools should have no problems.
I have two graphic cards, Intel HD4600 and NVidia GTX 950m. First thing I did was to check for updates. Everyday I check for updates and my laptop is up to date, but still Creo 4 SE is unuseable.
I wonder what happens if you uninstall Fall Creators Update (1709).
