3-Newcomer
July 27, 2018
Creo 5.0 Educational License Invalid
I think other people have found this out too. When I try to install Creo 5.0 Educational Edition it gives an error at the license step. Any idea when this will be fixed? I'm going to stick with 4.0 for now...
    AaronB3-NewcomerAuthor
    3-Newcomer
    July 27, 2018
    I can't reinstall 4.0 either. Please give us a valid license code or fix whatever it is that caused all student installs to fail.
    Update: Use BK500806ED0790-Y3M9-4RW5 as the license key and all should go well.
    I've been trying to install Creo 5.0 with code BK500806ED0790-Y3M9-4RW5 . It indicates license identification to be successful but the license source is indicated to be invalid file or format and I am unable to proceed. What do I do now?
    please upload your license file, I can check its contents.
    Sometimes installer has problems with network cards. Please open Command Prompt window, enter ipconfig /all > ip.txt command and upload ip.txt file. I will check its contents.
