Creo 5.0-[ License request failed for feature ][ HELP! ]
Hello! I installed the educational version of Creo 5.0, but I had problems with it. The problem is that, roughly, the license itself does not want to recognize. In the manual, I’ve done everything, and still I don’t have anything. I stopped it several times, but it still did not help.
The license itself took from the instructions:
BE410708EDSTUDENTEDK12
In the program itself it gives me this: Here is
Then I decided to enter the installer or the utility, but it still did not help, although the license
shows.
Then I decided to enter the installer or the utility, but it still did not help, although the license shows.
This solution to this problem or where I have not found, and do not even know what to do as I am at a complete impasse. The instructions did not say a word about this problem, and there was not even a hint of anything. As I didn’t do it anyway, I got into an unpleasant situation as the program itself refused to start, and that’s all. I restarted many times, and as you can see, it didn’t help me anyway, and even demolished the license and installed it again.
Please help solve this problem!Smiley Sad
please do following:
