CREO 7 Installation Issue
When working through the process to install CREO 7.0.2.0 the Installation Assistant seems to get stuck at the license identification portion. I've followed the instructions (removal of firewall/security etc.) and entered the provided code (BK700908EDSTUDENTEDUNI) and then logged in. The Installation Assistant hangs with the spinning processing icon.
Please show a screenshot of your issue.
P.S. Here's a possible solution: "Something is blocking the connection between PC and the licensing server. Please make sure that you temporary disable the antivirus and firewall during the licensing process".
