CREO 7 STUDENT VERSION - INSTALL PROBLEM
I need support.
I installed the Creo 7 student version with the Creo license but the program doesn't work.
My system is WIN10, 64 bits and I´m from Brazil
Reginato
HI @RM_9688567,
Can you please elaborate what is happening with the application?
Is it that you are receiving any licensing error while launching the application? OR
Is it that Creo Parametric exits with a flash screen? OR
Is it that Creo Parametric doesn't even pop up a flash screen?
Can you check if xtop.exe is displayed in the Details section in the Task Manager?
Hi @dpalakkandy
Yes, i'll try it ok.
No, the installation process was ok, no error message during it.
No, the icons, packages, folders, etc was installed but they doesn't work.
No, the xtop.exe doesn't display in task manager when I start my PC even I click on the icons.
More information:
1- When I click on the icon Creo Distribute batch appears the message below:
Code execution cannot continue because dlmmgrmt.dll was not found. Reinstalling the program to correct the problem.
2- Apparently Creo Modelcheck works.
3- The others programs doesn't work. (Creo  Direct, Simulate, Parametric, Layout)
Reginato
Hi @RM_9688567,
Thanks for the reply.
Can you right click on the shortcut of Creo Parametric > Open the file location > You would then be taken to the bin directory of Creo Installation. From the bin directory, try running parametric.bat file (Run as an administrator) and check if it helps in launching.
If it helps in launching Creo Parametric, add the below environment variable and launch Creo Parametric from the shortcut on the desktop:
  • Set the system environment variable ComSpec to %SystemRoot%\system32\cmd.exe
If in case Creo Parametric doesn't launch by running parametric.bat located in the bin directory, then i suspect that the issue is with the installation. The installation might be incomplete. You can confirm this by checking the availability of xtop.exe in the <Creo Install directory>\Common Files\x86e_win64\obj. If xtop.exe is not present in the obj folder, consider, uninstalling Creo Parametric and then try reinstalling the application by running the setup.exe as an administrator.
Let me know if this helps
