Creo 8 Parametric Command Prompt
HI
We have found that we can not run Creo 8 parametric anymore unless we run it with admin rights or if we unblock command prompt neither of which are an option within a school environment. The application just doesn't load after clicking the shortcut/icon.  Has anyone else had this issue and found a resolution.
@SR_7844589 wrote:
HI
please explain the term unblock command prompt. Attach screenshot showing current situation.
Note: If you can start Creo as Administrator then your problem is probably related to access rights to file system.
@SR_7844589 wrote:
HI
We have given all the files full permissions and the application will not load. If we unblock command prompt by allowing administrator tools to users creo runs even without any permission changes.
please provide detailed information:
  • which files you have changed access rights to
  • how do you run creo (publish shortcut properties)
  • please explain the term unblock command prompt
