Creo Elements/Pro Student stopped at 2% during installation.
  • February 1, 2012
  • 3 replies
  • 1955 views
So when finishing the download/install process for the program the download shows to be 100% done BUT the copy files bar is stuck at 2% and doesn't change at all. When I tryed again I got the same results. Can anyone help me solve this probelm. I really need help on this one.
    18-Opal
    February 1, 2012
    Hi Carlos,
    You are trying to install using the install from the web utility. This will pull files down during installation. If there was a network glitch, it might be freezing at that point.
    What I recommend is to download the full media from the link below.
    Creo Elements/Pro Student Edition
    Once you have it downloaded, extract the zip file and start setup.exe to perform a fresh install from the local machine.
    mark
    I purchased the student edition by journeyEd 5.0, I have problem downloding it freeze at 2%.
    Jimmi
    You can use "Free Download Manager" to download the package.
