Sep 27, 2014 10:58 PM UTC
Creo Layout
I have 2 questions.
1. I have assembled a *.cem (creo layout 2.0) but I can's see any of the lines I sketched in creo layout 2.0.
2. I have creo parametric 2.0 m070 (academic) but I didn't find the button to start creo layout direct from creo parametric.
What have I mised or have I only the wrong version?
    MarkCheliAnswer
    Oct 1, 2014 12:47 PM UTC
    Hi Robert,
    While I don't have very much direct experience in using this function, I believe that this video will provide a pretty good introduction to what you're trying to do.
    http://learningexchange.ptc.com/tutorial/4106/using-creo-layout-in-3d-design
    Please let me know if you have any more questions!
    Sep 29, 2014 12:14 PM UTC
    Hi Robert,
    Would you mind attaching the files so I can give it a try? Also let me make sure that I am understanding you correctly...
    So you've created a Creo Layout file and assembled it, but you can't see the lines create in Creo Layout.
    You want to launch Creo Layout directly from Creo Parametric? Is there any particular reason for this?
    robwood1-VisitorAuthor
    Sep 29, 2014 4:33 PM UTC
    @1. Yes it's correct. I cant see the lines.
    @2. No speciall reason. I would only know if it is working.
    I have no special assembly I would only testing the function.
    MarkCheli5-Regular MemberAnswer
    Hi Robert,
