MartinHanakAnswer
Aug 28, 2023 7:19 AM UTC
at the end of PDF file you can see following information...
This means that product code BK900908EDSTUDENTEDUNI belongs to Creo 9.0.
To install Creo 10.0 please use https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf instructions.
Do not forget to remove all license file from C:\ProgramData\PTC\Licensing directory before you start Creo 10.0 installation.
