Jan 20, 2012 10:28 PM UTC
Creo Parametric license request failed
My computer runs windows 7 64 bit and meets all of the specifications for Creo.
I have my product code, but everytime I run the setup wizard to generate the license it returns this:
A failure occured during license generation.
An unknown error occured requesting a license file be generated from ptc.com
I am using this software in an engineering elective at Univerisity of Alabama Birmingham.
    dorlovAnswer
    Jan 26, 2012 6:54 PM UTC
    Hello Josh,
    i do not see any reqiests from you...can you please email me your PTC HOST ID and will create the license file for you.
    thanks
    Dima
    Jan 21, 2012 8:56 AM UTC
    Try to conract with "PTC Academic Support": http://www.ptc.com/go/academic-support
    Jan 26, 2012 6:42 PM UTC
    still having the same problem, contacted academic report several days ago and still waiting on a reply.
    dorlov1-VisitorAnswer
    Hello Josh,
    thanks
    Dima
    May 18, 2012 5:32 PM UTC
    Good day, Dmitry
    I downloaded Creo Parametric 1.0 Schools Edition quite sometime back. I had sent request for the lisence file, however no reply from anyone to date. Is it possible for you to create a license file for me, if I give you my PTC Host ID?
    Sivaroopan
    Sep 23, 2013 11:47 PM UTC
    I'm having the same problem, and was wondering how I can get in contact with the Academic Support Team. I can't find an email address.
    Sep 24, 2013 1:34 AM UTC
    All Academic support should go through our PTC Academic Support page where you can find a solution yourself or submit a support request from the bottom of the Request Academic Support tab.
    Sep 24, 2013 2:58 AM UTC
    Thanks, Adam. I appreciate the help.
