Aug 8, 2013 4:04 PM UTC
Creo self closing - Quality Agent error 0xc6000005
Every time I try to open Creo, a text box pops up telling me that creo will close because it couldn't run the "Quality Agent" and it is required to do so. I am told to report error code 0xc6000005.
I have never had any issue running Creo before.
    Aug 8, 2013 4:14 PM UTC
    Elliot,
    There are certain graphics drivers that have been causing problems with Quality Agent. Try the tips listed here and if you still can't get it working, please file a support request at www.ptc.com/go/academic-support and someone from our support team will contact you. There is another solution for this problem, but it requires us to remotely access your computer.
    Chris
    Aug 22, 2013 4:29 PM UTC
    I'm having the same problem as the one above. I have used creo before but had to reinstall it.
    I'm using the student version btw.
    Aug 22, 2013 4:39 PM UTC
    Michael,
    Have you tried following the tips listed here? If you have and it's still not working, please file a support request at www.ptc.com/go/academic-support and someone from our support team will contact you.
    Chris
