3-Newcomer
Dec 8, 2025 10:15 PM UTC
Creo University Edition
I am installing Creo University edition and I entered BK120908EDUNIVERSITYED under sales number order or product code. It didn't go through and displays ERROR in red.
Dec 9, 2025 7:12 AM UTC
1.] BK120908EDUNIVERSITYED is Product code
2.] You can contact academicsupport@ptc.com (via e-mail). You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
  • if Ethernet network card is installed in your computer then use its physical address
  • if the only network card is WiFi network card then you must turn off MAC address randomization to get real physical address
3-Newcomer
Dec 21, 2025 2:39 AM UTC
Thank you, this worked.
Catalina
Community Manager
Dec 12, 2025 6:50 PM UTC
Hi @MM_14430813
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
3-Newcomer
Thank you
