Creo visualization
Getting an authentication error when trying to publish Creo objects in FIRST server. Looks like visualization worker doesn't like something about the requesting context.
M1
1233624
Manual
0000153818
NYLOCK NUT, 10-32 _
A.1
Job Log
Sep 23, 2014 11:39:56 AM:Start Job: CAD Part - am-1042_.prt, A.1
Sep 23, 2014 11:39:56 AM:make temp dir /d00/edu/Windchill/tmp/pubtemp/publish13144781593472716.tmp
Sep 23, 2014 11:39:56 AM:"As Stored" Config Spec is available
Sep 23, 2014 11:39:56 AM:The EPMDocument As Stored Config Spec was selected as the default
Sep 23, 2014 11:39:56 AM:Start: CAD Part - am-1042_.prt, A.1
Sep 23, 2014 11:39:56 AM:Authoring Application: Creo
Sep 23, 2014 11:39:56 AM:Transferring Files to: /d00/edu/Windchill/tmp/pubtemp/publish13144781593472716.tmp
Sep 23, 2014 11:39:56 AM:Error: Unable to Authenticate. Contact your system administrator and review the Method Server log for more information.
Sep 23, 2014 11:39:56 AM:Number of Files (identified to be) Transferred: 0
Sep 23, 2014 11:39:56 AM:Attempting to delete temporary workspace publish13144781593472716.tmp.
Sep 23, 2014 11:39:56 AM:Done deleting temporary workspace publish13144781593472716.tmp.
Sep 23, 2014 11:39:56 AM:No content to process
Sep 23, 2014 11:39:56 AM:End: CAD Part - am-1042_.prt, A.1
Sep 23, 2014 11:39:56 AM:End job (with error): CAD Part - am-1042_.prt, A.1
Sep 23, 2014 11:39:56 AM:Publish Complete event dispatched
Sep 23, 2014 11:39:56 AM:remove temp dir: /d00/edu/Windchill/tmp/pubtemp/publish13144781593472716.tmp
sm_01Answer
Should be all set now. Can you please try again?
Walter, did you delete the files? I do not see any CAD files in your Project?
Yup, cadworker is not happy.
PTC IT has been informed. Until it is corrected, you can always use the Custom Check In option in Creo to create the Creo View files as part of the Check In operation. You'll see each model being processed pop on the screen temporarily while it is being converted, but it is pretty quick. This makes the Creo View files ready immediately in Windchill vs. being sent to a publishing queue for processing.
sm_011-VisitorAnswer
