Mar 11, 2011 4:58 AM UTC
Delet Old Version
I am running out of hard drive space and i wanted to know what is the best way of deleting old versions of parts or assemblies? (for example it saves prt.2 and prt.3 and the latest is prt.4, so i only need the latest)
thanks,
Itzik
    s.iyerAnswer
    Mar 11, 2011 8:21 AM UTC
    There are Two methods.
    Method 1: You wish to delete older versions of a PARTICULAR part or assembly
    File --> Delete --> Delete Old Versions
    Method 2: You wish to delete ALL older Versions of all the files present in Working directory
    Window --> Open System Window [opens a system window]
    Type "Purge" and enter.
    Type "Exit" to exit from the system window.
    s.iyer1-VisitorAnswer
