demo examples from the developer zone
1. I can't install and run the PC EMS demo example from developer zone. Apparently something was done, because I reached the maxim (5) instances. Don't know how to erase them to make place for other tries.
Error messages examples
in browser
a) localhost:8088/static/index.html was not found on this server (Thingworx HTTP Server (Win32))
in command window (dos):
a) device.cloud.thingworx.com:80++>
this site can't be reached; localhost refused to connect; ERR_CONNECTION REFUSED ; Details localhost 8088 static index (same with 8080)
b) succcsessfully connected saving .booted config file
error file not found c:\users\Corneliu\AppData\local\Temp\7ZipSFX.002\etc\config.json
disconnect socket
disconnecting from server
W 8.1 (64) computer
2. Cannot see at all the smart phone demo example from the developer zone.
3. Are these examples compatible with w 8.1 or with w10? If not what Windows should we run?
Thank you very much.
Corneliu
