Download links not working
We are a FIRST Robotics team and we are trying to download Creo Illustrate from this Site
http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
When we click Download Manager we are getting 404, the same message when we click on https. Can you please fix the links so that we can download Creo Illustrate 5.0.
Robo Minions
Team 11142
rvedula-2Answer
Here is what we got from academic support.
Please follow the steps in the link below to install the PTC Creo 5.0 Schools Premium Standalone Edition:
  1. Installation instructions: http://apps.ptc.com/schools/references/install_creo5_schools_premium.pdf
BH500902xxxxxxxx-MDV6
I will try with 4.1 and see if this works.
Ram
Thanks for letting us know, I'll work on fixing the link. Until then, please download Creo Illustrate 4.1 from:
http://www.ptc.com/appserver/auth/it/esd/academic.jsp
Alex
rvedula-21-VisitorAuthor
Hi Alex,
We are using Creo 5.0 student license and will 4.1 work with 5.0? If not we need to re-install Creo 4.0 to work. Can you please send us the Creo 4.0 License so that we can try using with Creo Illustrate 4.1.
Robo Minions
FTC Team 11142
Creo Illustrate 4.1 should work fine with the Creo 5.0 license. In case you have any issues, please let me know and I'll find a solution.
Please note that Creo Schools Premium has the license for Illustrate Standard, so in the window that will ask for the license you will need to select Standard and you will also need to copy the license path (C:\ProgramData\PTC\Licensing\BH500.......dat).
Alex
