May 3, 2013 12:22 PM UTC
Drawing formats not visible in CREO2
We are trying to set up CREO2 on a RM Connect 4 network.
I have created a number of Drawing formats that include borders, title block and School badge and they have been placed in C:\program files\ptc\creo2.0\common files\MO30\creo_standards\formats.
When I try to create a new drawing from a part and select 'Empty with Format' the formats do not appear.
Can anyone explain what is happening here?
I have used the same formats in the same location on my own stand-alone computer with no problem.
Thank you
    May 3, 2013 1:39 PM UTC
    Hi Roy,
    Are you using one of the Academic configuration files? If you are, it will look for formats in ".....\creo_standards\formats". If you are not, it will look for formats inside of "...M030\formats".
    The config.pro option to define this is "pro_format_dir".
    If all is in order and you still can't see them, is it possible they are hidden or you don't have read access?
    Hope this helps.
    Adam
    May 3, 2013 1:54 PM UTC
    Hi Adam
    I'm not entirely sure what you mean by 'Academic Configuration Files'. Could you explain further?
    Roy
