endpoint reconnection error when deploying EMS code
I am facing an issue with endpoint reconnection unsuccessful error when deploying the ems code. I tried changing the proxy settings but still the error exists. I am not able to get the data on ThingWorx. I am getting the following result while executing:
Simulated Data supported...........
SimulateTimer.Set.run() Tue Apr 26 09:49:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:49:28 IST 2016
09:49:28.390 [main] INFO c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
09:49:28.540 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
09:49:28.557 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 8
09:49:28.596 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.nio.ch.DirectBuffer.cleaner(): available
09:49:28.597 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: available
09:49:28.599 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.theUnsafe: available
09:49:28.600 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.copyMemory: available
09:49:28.601 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Bits.unaligned: true
09:49:28.602 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
09:49:28.607 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 8
09:49:28.607 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
09:49:28.608 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
09:49:28.609 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
09:49:28.610 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
09:49:28.611 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes. Please check the configuration for better performance.
09:49:28.611 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\PREETH~1\AppData\Local\Temp (java.io.tmpdir)
09:49:28.612 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
09:49:28.612 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
09:49:28.649 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
09:49:28.649 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
09:49:28.972 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 4
09:49:28.972 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 4
09:49:28.972 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
09:49:28.973 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheCleanupInterval: 5000 ms
09:49:28.991 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
09:49:28.994 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:49:28.995 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:49:28.995 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:49:28.996 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
09:49:29.092 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0xbf101f470ca3ac88
09:49:29.106 [Client-EndpointMonitor-1] DEBUG i.n.channel.ChannelOutboundBuffer - -Dio.netty.threadLocalDirectBufferSize: 65536
09:49:29.107 [Client-EndpointMonitor-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
09:49:29.143 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
09:49:29.240 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
SimulateTimer.ReSet.run() Tue Apr 26 09:49:38 IST 2016
09:49:39.153 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:49:39.154 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:49:39.155 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:49:40 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:49:48 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:49:52 IST 2016
09:49:54.154 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:49:54.154 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:49:54.154 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:49:54.154 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.ReSet.run() Tue Apr 26 09:49:58 IST 2016
09:50:04.155 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:50:04.159 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:50:04.159 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:50:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:50:08 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:50:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:50:18 IST 2016
09:50:19.159 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:50:19.159 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:50:19.159 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:50:19.159 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:50:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:50:28 IST 2016
09:50:29.161 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:50:29.161 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:50:29.161 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.ReSet.run() Tue Apr 26 09:50:38 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:50:40 IST 2016
09:50:44.161 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:50:44.161 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:50:44.161 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:50:44.161 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.ReSet.run() Tue Apr 26 09:50:48 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:50:52 IST 2016
09:50:54.162 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:50:54.162 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:50:54.162 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.ReSet.run() Tue Apr 26 09:50:58 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:51:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:51:08 IST 2016
09:51:09.161 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:51:09.161 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:51:09.161 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:51:09.162 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:51:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:51:18 IST 2016
09:51:19.165 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:51:19.165 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:51:19.165 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:51:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:51:28 IST 2016
09:51:34.165 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:51:34.165 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:51:34.165 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:51:34.165 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.ReSet.run() Tue Apr 26 09:51:38 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:51:40 IST 2016
09:51:44.166 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:51:44.166 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:51:44.167 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.ReSet.run() Tue Apr 26 09:51:48 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:51:52 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:51:58 IST 2016
09:51:59.167 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:51:59.167 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:51:59.167 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:51:59.167 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:52:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:52:08 IST 2016
09:52:09.168 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:52:09.168 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:52:09.168 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:52:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:52:18 IST 2016
09:52:24.168 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:52:24.168 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:52:24.168 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:52:24.168 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:52:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:52:28 IST 2016
09:52:34.169 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:52:34.169 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:52:34.169 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.ReSet.run() Tue Apr 26 09:52:38 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:52:40 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:52:48 IST 2016
09:52:49.168 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:52:49.168 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:52:49.168 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:52:49.168 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:52:52 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:52:58 IST 2016
09:52:59.170 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:52:59.170 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:52:59.170 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:53:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:08 IST 2016
09:53:14.169 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:53:14.169 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:53:14.169 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:53:14.169 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:53:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:18 IST 2016
09:53:24.170 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:53:24.170 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:53:24.170 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:53:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:38 IST 2016
09:53:39.170 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:53:39.170 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:53:39.170 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:53:39.170 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:53:40 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:48 IST 2016
09:53:49.171 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:53:49.171 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:53:49.171 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:53:52 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:53:58 IST 2016
09:54:04.171 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:54:04.171 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:54:04.171 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:54:04.171 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.Set.run() Tue Apr 26 09:54:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:54:08 IST 2016
09:54:14.172 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:54:14.172 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:54:14.172 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:54:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:54:18 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:54:28 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:54:28 IST 2016
09:54:29.172 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:54:29.172 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:54:29.172 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:54:29.172 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.ReSet.run() Tue Apr 26 09:54:38 IST 2016
09:54:39.175 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:54:39.175 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:54:39.175 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:54:40 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:54:48 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:54:52 IST 2016
09:54:54.175 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09:54:54.175 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: HvacGateway, id: 0]. Attempting [re]connect...
09:54:54.175 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09:54:54.175 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
SimulateTimer.ReSet.run() Tue Apr 26 09:54:58 IST 2016
09:55:04.176 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
09:55:04.176 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
09:55:04.176 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: HvacGateway, id: 0]
SimulateTimer.Set.run() Tue Apr 26 09:55:04 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:55:08 IST 2016
SimulateTimer.Set.run() Tue Apr 26 09:55:16 IST 2016
SimulateTimer.ReSet.run() Tue Apr 26 09:55:18 IST 2016
Just to follow up on the other post, is this setup to run with SSL? The reason I'm asking is because it seems to timeout waiting for the websocket handshake to complete, and you've pointed it to localhost:80. Is your platform at port 80? Can you try adding a self-signed certificate to your Tomcat and then connecting over wss instead? Here's a quick guide on how to setup SSL on Tomcat.
pnali1-VisitorAuthor
hi,
thanks for replying. when I click the link for setup of SSL, the page is redirected saying as Access denied. Can you suggest some other way to setup SSL on tomcat.
