Aug 6, 2013 12:17 PM UTC
error 0xc6000005
based on the title, my copy of student edition couldn't run creo parametric because it could not run quality agent.
any suggestion?
    Aug 6, 2013 2:03 PM UTC
    Amir,
    There are certain graphics drivers that have been causing problems with Quality Agent. Try the tips listed here and if you still can't get it working, please file a support request at www.ptc.com/go/academic-support and someone from our support team will contact you. There is another solution for this problem, but it requires us to remotely access your computer.
    Chris
    Aug 6, 2013 3:59 PM UTC
    Hi
    Thank you for your help. The problem has been tended to thank you.
