Jan 6, 2010 5:06 PM UTC
Error message "License request failed for feature...&qu
I purchased ProE Student Edition last February. It worked fine initially. Now, though, when I try to start ProE I get a message box that says "License request failed for feature PROE_StudentEdition4: -9 Invalid host" (followed by some other details). Once I click OK, ProE closes. What does this mean? I'm not very knowledgeable of computer know-how beyond basic usage. Can anyone explain in a simple way how to fix this problem?
    Jan 18, 2010 4:00 PM UTC
    I've seen this a few times. I suspect that every so often, ProE phones home to make sure that your local license is valid. If it does this while you're not connected to the Internet, it pops the error message. In my cases, this terminates the program right now, without even saving your work, which can be irritating. To get beyond the problem, I connect to the 'net and re-launch the program. This worked for me two or three times last night. Might just be a coincidence, but it's easy enough to try. Oh yes, and save your work frequently, because while it almost always does the check on start-up, it also appears to do it occasionally during your session. One other thing--the most recent time I was dealing with this, I appeared to be connected via wi-fi to the school's network. I could not get the error to resolve, though, until I jacked into the wired connection. Not sure whether there was a problem with the wi-fi, or if ProE somehow requires a wired connection. That seems unlikely, but I'm putting it out there as a possibile vertex.
    Mar 1, 2010 10:58 PM UTC
    I'm having this same problem and cannot find a fix. I am connected to my school's network by an ethernet cord so that's not the issue. I can't even find the customer support email address. If anyone could post the ptc support email that would be very helpful. Thanks!
    Mar 2, 2010 3:24 PM UTC
    hi all ...please contact us via -
