error while installation
After installing creo 5.0 this is showing license requesting failed for feature. tell me what to do........
    VipulTAnswer
    HI SS_9630153,
    I believe you are trying to use the product code valid for creo parametric academic version 4.0 with 5.0.
    Please use product code BE500806EDSTUDENTEDK12 to work with Creo Parametric 5.0
    To have detailed information please click here
    Vipul
    you must reconcile the contents of the parametric.psf file with the license file located in C:\ProgramData\PTC\Licensing directory.
    Please upload these files, if you want additional help.
    In parametric.psf where should i looks for the  C:\ProgramData\PTC\Licensing directory.
    Steve.
    Hi @SS_9630153,
    Open the parametric.psf in notepad and look for the entry shown below
    Also, make sure your license file is located in default location as mentioned.
    Vipul
