Jan 21, 2013 7:59 PM UTC
Everything is inverted?
Hi there people, ive just installed and loaded creo parametric student edition 2.0 and everything seems to be inverted in the working window, exactly like this http://i.imgur.com/UoMXX.png.
Any help would be much much appreciated
    Feb 18, 2013 12:56 AM UTC
    Hey, if youre using parallels here's a something that may help you, I know this is dated but who knows, maybe it will help someone else:
    I had this same issue, the vertical mapping of the mouse was messed up to (mirrored about the horizontal center line of the screen) Here is the fix:
    open up Creo Parametric
    File > Options > Configuration Editor
    click the Add... button at the bottom of the window
    under option name type: graphics
    change the Option Value to win32_gdi
    click ok
    go to the bottom of the window to the pull down menu next to the label options: import/export
    choose "export all options to configuration file"
    safe as the default "config.pro"
    This should solve the problem
    Feb 18, 2013 11:14 AM UTC
    It would also be worth trying this command in your config.pro as an alternative to win32_gdi.
    use_software_opengl yes
    It should fix the graphics problem but have less impact on Creo performance.
    Feb 18, 2013 3:03 PM UTC
    Please see the comment on this post for information on the graphic settings.
