Freeform
How do I combine several freeform shapes to make an object that can be exported as an .STL file?
example.jpgThe eyes and nose of this animal are seperate freeform objects. I would like to extrude a cut through the "snout" to make a mouth. I'm sure somewhere I saw a command to convert freeform to object- I'm looking for some kind of boolean add command I think!
Any pointers?
Best regards
Peter
    Peter, I love the character you have created.
    • After creating the overlapping freestyle features, select them all in the model tree (holding down Ctrl).
    • In the Model tab, Editing group, select Merge then OK in the ribbon.
    • With the Merge feature selected in the model tree, in the Model tab, Editing group, select Solidify then click OK in the ribbon.
    You now have a solid that can have the mouth shape removed maybe with a symmetric extrude.
    A zip of a model I created applying this technique is attached.
    PeterSach1-VisitorAuthor
    Cheers Tim
    Struggling with this.
    Todays design intent....
    I've modelled the fairy (weight for a ballon) have managed to combine the hear and the wings but cannot get the body to merge/solidify. I suspect it it because it is self intersecting.
    I've attached the file
    Many thanks for your help.
    Peter
    You mention the most common reason for a shape failing to solidy/thicken.
    Look out for very tight curves and also the control frame overlapping. If solidify wont work try thicken with a very thin section. Creo should thicken most of the model (grey) but not the problem areas (blue) which help focus in on the surfaces that need tweaking..
    I tried downloaded the zip file to take a look but the part had the wrong extension.
    Try uploading the native Creo part file and I will have a look.
