From PTC: Windchill Upgrade Status
For teams using Windchill that have been experiencing issues, the problem can be solved by updating to the latest build version of Creo 3.
To do this, you should request a new product code from - and download the Creo 3 image from http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp. Install the Creo 3 image and enter your product code for licensing. Once Creo is installed you should be able to follow the normal steps to connect to Windchill and access your project.
