Nov 16, 2010 7:01 PM UTC
Fuel Tank
So according to the constraints there needs to be a space for a required amount a fuel. I was wondering, do we need to design a fuel tank to reside inside of the wing or simply leave space for it.
Nick
    mfischerAnswer
    18-Opal
    Nov 17, 2010 1:42 PM UTC
    Hi Nick,
    You would need to create a fuel tank for your design. In the instructional video I will illustrate the process to do this. Keep in mind the overall weight of the fuel is 40,000 lbs. Since we are creating a single wing, we are only concerned about half the weight in fuel.
    You need to evaluate the size of the tank to fit this amount of fuel. I will describe the process for all teams in the videos.
    It will need to be confined between the spars and 15% and 70% of the chord span.
    Mark
    mfischer18-OpalAnswer
    18-Opal
    Hi Nick,
    Mark
    NickVallo1-VisitorAuthor
    Nov 17, 2010 6:10 PM UTC
    Thankyou
