Nov 22, 2016 5:00 PM UTC
how do I change the language?
I have a due project and the language is in Spanish I wish to change it back, help me please.
    Nov 23, 2016 6:36 AM UTC
    1. default Creo language is English, this language version is always available
    2. other language versions are available only in case that they were selected during Creo installation
    3. language setting is performed via parametric.psf file located in Parametric\bin directory in Creo installation
    Add the following line at the end of parametric.psf file, if you want to use English version of Creo:
    ENV=PRO_LANG=english
    Languages supported:
    LanguageEnvironment Variable Name
    Chinese Simplifiedchs
    Chinese Traditionalcht
    Frenchfrench
    Germangerman
    Italianitalian
    Japanesejapanese
    Koreankorean
    Spanishspanish
    EnglishC or english
    Russianrussian
    See also:
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110907
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS147730
    MH
    Frenchfrench
    Germangerman
    Italianitalian
    Japanesejapanese
    Koreankorean
    Spanishspanish
    EnglishC or english
    Russianrussian
    See also:
    MH
