How to close a surface after a surface trim?
Hello, I am making a surface model and have been left with a fairly complex hole after a sweep-surface trim. I can select all the edges that would close the hole, but can't seem to figure out which feature will make it happen. Boundry blend in blanked out no matter what I do or select, and I'm wondering if this might be it? Also, is there a way to "heal" these surfaces as the cut goes thru so later I don't have to close them? Thanks, Matt
    Matthew, It's really hard to tell without actually seeing your model. Is it small enough to email or if not, could you forward some images of it? Thanks, Adam Haas -
