How to figure out total weight of the aircraft?
In past years, RWDC provided the means to estimate total weight. How exactly are we supposed to go about calculating the weight of the different components of our aircraft, including the wing and fuselage?
    If you are designing your own components then CREO should give you a weight based off of the material. Overall the total weight is the most important concern.
