How to use Blend or Variable Section Sweep to create an extruded part?
- 6 replies
- 7026 views
- Translate All
Starting from the attached box, having dimensions 7,4,3 mm, I want to use either Blend, Variable Section Sweep with two trajectories, or Extrude up to a datum plane created by specifying three points, to create the attached extruded part, with the dimensions specified in the image.
After going over quite a few tutorials, I still have no idea how to approach this question. Is there any chance you will be able to guide me through the process using each one of the methods I mentioned? (i.e. Blend / Variable Section Sweep / Extrude)
Thank you!
