Hi, I was able to open the models you supplied and noticed your first component in the assembly has no constraints. This is a critical problem. You CANNOT leave the first component in the assembly unconstrained. I tried changing it to be Default, but then the location of many other components becomes jumbled up. I tired to set the first component to FIX constraint, which would keep it in its current location, but many of the components in the arm assembly become jumbled up.
My suggestion would be to go through the assemble one-by-one, starting at the first component to ensure all the components are assembled with proper constraints. There are many components in this assembly that are not properly constrained which is causing the parts to move around and the mechanism to fail. You will not be able to use Mechanism mode on this model until all the placement issues are resolved.
