I can't open a new file on creo parametric 3.0
Hello, I'd like to ask help, because, when I'm trying to create a new file ( manufacturing) on creo parametric 3.0, nothing happens. The screen spend all over the time completely white.
VladimirNAnswer
There was a similar question before:
VladimirN24-Ruby IVAnswer
when Creo window is white after creation of new object, then you can try adding following option into config.pro file.
graphics win32_gdi
  • use Notepad to add the option at the end of config.pro file
  • restart Creo
