Feb 9, 2016 7:25 PM UTC
I cant give dimensions on Creo 3.0 student
I installed the software today & cant give dimensions on creo 3.0 students version.
please help me, as you can see the line in the picture without the option to give dimension.
thanks a lot
    Feb 10, 2016 6:27 PM UTC
    are you sure you want to use Creo Layout application ? I would expect that you want to use Creo Parametric.
    Idea: Look at Annotate​ tab.
    MH
    Feb 9, 2016 8:12 PM UTC
    I would recommend upgrading your graphics card driver as this seems to be a graphics issue.
    Let me know how it goes.
    Chris
    yayalon1-VisitorAuthor
    Feb 10, 2016 9:10 AM UTC
    Chris thanks a lot for your reply.
    I run on my system solidworks, inventor and autocad perfectly well.
    I think it will be better to download an older version of creo ! what do you think?
    best regards and again thanks a lot
    Yonatan
    MH
    Feb 14, 2016 5:10 PM UTC
    Thanks a lot for your help.
    It turned out that Martin was right.
    As I used Creo Parametric there wasn't any problem to give dimension.
    Again thanks
    Best Regards
    Yonatan
