I completely installed Creo but I do not know where to access it or open it?
I have installed Creo 3.0 for university students for the free 30 days. The PTC Creo parametric, PTC creos imulate 3..., and PTC Creo options show on my wallpaper but when I click them, it says "missing shortcut," and "windows is searching for parametric.exe..."
Can anyone PLEASE tell me how to open it? I have Windows 8. I believe I installed it correctly. (I used license code and it said "success" and then "finish".)
Thank you in advance!!!
I'm facing your issue too, I noticed the file "parametric.exe" is missing. Do you or somebody from PTC have a solution?
Thanks in advance
Luca
Propably a bit late, but there is a copy of this thread somewhere else where I found a "solution":
Re: I completely installed Creo but I do not know ... - PTC Community
Problem is the 64bit version. Don't know what exactly causes the problem. So install 32bit version and you should be fine.
Regards
