Import obj file to creo parametric 6.0
Hi does anyone know if i can import and modify an obj file in creo parametric 6.0 student?
If so could you please explain the process?
try this ...
  • File > Open
  • at the bottom of the window set Type to All Files (*)
  • select obj file
  • click Import button
Note: I am not sure whether Student license enables you to import obj file.
