Installation Poblems with Creo Illustrate using "normal" Academic Creo-Versions
Dear Support-Team! We have learned, that Creo Illustrate 6.0 is included in the Creo 6.0 Academic license. Since we do NOT use Creo 6 I have now tried to install different versions of Creo Illustrate (4.1, 5.1, 6.0) using "normal" Creo 5 and 7 academic licenses (beginning with BE5.... , BE7... ) without success. There is always an error "No such feature exists". Is there any possibility to run Creo Illustrate without using the Creo Premium versions? Best regards Peter Thurner
    Creo 5.0 doesn't have Illustrate included, and Creo 7.0 now has Illustrate 7.0 (will be available tomorrow in the academic download links). Creo 7.0 used to have a license for Illustrate 6.1 and now that Illustrate 7.0 got released, we changed that so you have access to the latest release.
    here is a direct download link that will work until we finish the publishing process for Illustrate 7.0:
    http://apps.ptc.com/schools/MED-60912-CD-070_7-0-0-0_Creo-Illustrate.zip
    Alex
    Hello Alex!
    Thanks a lot for your very fast and helpful reply!
    I´ll try the installation of Illustrate 7.0!
    Best regards
    Peter
