Installing Creo 2 license server on a virtual server
Our school has got Microsoft 2012 virtual server standard R2, and am trying to install the floating license server.
Tried to install using the instructions provided:
Download media
  1. 2. Start setup.exe on the server machine
  2. 3. Select Setup License
  3. 4. Accept License agreement
  4. 5. Type the product code in the field
  5. 6. Click Install Licensing - at this point I get - error
  6. 7. Click Finish
then read the pdf about flexinet license
In general, the process of using the HPV_UUID would follow this outline:
1. Identify the virtual machine on which the license server will be run, and download the platform-specific
lmhostid utility from the Flexera Software website.
2. Run the command lmhostid -ptype HPV -uuid at the command line of the virtual machine where the license
3. Modify the license certificate to configure server parameters (like TCP port number, options file, or other
4. Launch the license server on the virtual machine by pointing to the license certificate.
5. If the license server has to be moved to another physical machine, simply copy the virtual machine image
Problem is I can't find the lmhostid utility on the flexera website can anyone point me to where I can get it, or let me know any other method
thanks
gchadwickAnswer
Sorted thanks to academic support, upgraded us from creo 2 to creo 3 and it installed no problem, just contact them on Academic Case Logger
gchadwick1-VisitorAuthorAnswer
