7-Bedrock
October 16, 2020
Invalid Server Location Education Version
If I try to connect with the education license to our Windchill system, I get the Invalid Server Location Error.
I checked many articles (CS174534, CS185244, ...)  here but nothing is working:
  • I reinstalled Creo
  • I set some environment variables (I checked the env with a system which is working and found not one env variable about creo there?)
  • I checked the server adress
  • Even if I try to start the CreoAgent manually nothing happens
Probably, I am missing the one obvious hint. So thanks for help.
Kind regards,
Arn
