Mar 15, 2020 1:08 PM UTC
Lauching setup.exe and nothing happens
Hello
I downloaded the 4 Gb zip "MED-100WIN-CD-430_6-0-2-0_Win64" and unzipped it. When I disable my anti-virus and try to open "setup.exe" as an administrator, nothing happens... I tried many times. My Computer OS is Windows 10 and I'm trying to install CREO 6.0
Can someone help me ?
Thank you in advance for your answer,
Have a nice day !
Mar 16, 2020 12:39 PM UTC
maybe the problem is related to network card(s).
Please run ipconfig  /all > ip.txt command in Command prompt window and upload ip.txt file. I can check its contents.
Mar 16, 2020 12:45 PM UTC
Thanks for answering, I did that, it's in french because my computer is configurated in french so I'm sorry for that.
I've uploaded the ip.txt file.
Ludovic
Mar 16, 2020 12:56 PM UTC
suggestions:
1.] switch you user environment to English
2.] disable IPv6 protocol
3.] set primary DNS server to 8.8.8.8
3-Newcomer
Apr 20, 2022 11:17 AM UTC
Hi there,
I had this same problem yesterday. In my case, the problem was that the installation folder was in the "downloads" folder.
As soon as I moved it to C: and launched again the install.exe, everything worked fine.
Hope it helps someone (or at least my future me in a couple of years 😉
