License file not recognized
Hi!  I have tried everything for the installation, I have read all the possible problems and solutions there are. My problem is that the license file (.dat) is not recognized by the assistant. I select it and also put the installation code at the same time but it says: format not recognized and I can not click next. Thank you for your help.
Please submit your request in "Academic Support Request" form: Academic Case Logger
