License re-installation required each time I switch from university site use to home use
Hello, Would you help me please?
I have the student version installed for my degree course and have different locations from which I access the license.
Each time I move location, the software requires that I re-install the license.
Is there a way around this please?
Thank you
John
I guess that university Creo license is floating one. Therefore you can contact university CAD admin and ask him to borrow university Creo license for your personal computer.
path to license is defined in parametric.psf file located in Parametric\bin subdirectory.
Info is available in two following lines:
ENV=PTC_D_LICENSE_FILE-=...
ENV=CREOPMA_FEATURE_NAME=...
Please put parametric.psf file into zip archive and upload zip archive.
Hello, zip file as requested.
John
John
I can see following line in parametric.psf ...
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK700908EDSTUDENTEDUNI_license.dat;C:\ProgramData\PTC\Licensing\BK800908EDSTUDENTEDUNI_license.dat;C:\ProgramData\PTC\Licensing\BK700908EDSTUDENTEDUNI_license.dat
3 license files are mentioned
Info:
  • 3rd entry is duplicate of 1st entry
  • BK700908EDSTUDENTEDUNI_license.dat contains license which enables you to launch Creo up to release 7.0
  • BK800908EDSTUDENTEDUNI_license.dat contains license which enables you to launch Creo up to release 8.0
Also I can see following line in parametric.psf ...
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
Info:
  • when you start Creo (which release ?), it looks in the license file and looks for the line INCREMENT CREOPMA_Student6
  • if Creo locates INCREMENT CREOPMA_Student6 then it starts successfully
Note no.1:
The following line is sufficient
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK800908EDSTUDENTEDUNI_license.dat
Note no.2:
It is necessary to check whether BK800908EDSTUDENTEDUNI_license.dat contains INCREMENT CREOPMA_Student6
Note no.3:
Every INCREMENT block contains HOSTID=PTC_HOSTID=xx-xx-xx-xx-xx-xx key, where xx-xx-xx-xx-xx-xx is physical address of network card.
It is necessary to check whether xx-xx-xx-xx-xx-xx is equal to physical address of your network card.
Network card information can be displayed using command ipconfig /all
You can also forward information into ip.txt file using command ipconfig /all > ip.txt
If you will send me BK800908EDSTUDENTEDUNI_license.dat and ip.txt, I can provide you more information.
