Licensing failed
i used the code from the student pdf, but licensing always failed.
Work on a 64 bit Windows 10 Machine.
Can somebody help me
    i got the same problem.
    Creo 2 works fine but i need to install Creo 3 for homework, because my university already uses Creo 3.
    Please help
    I got the same Problem, too.
    I want to install Creo 3.0. After using the license-code from the pdf and entering my username and password, I got an error. (Username and password both correct!!!)
    I tried to skip the part with the license, but then I will be asked for the license when I opened creo and I can´t use creo.
    Please help!
    got the same licensing problem with the academic version of Creo 3 (WIN10-64).
    My Username/Password are not accepted during installation, but there is no problem for me to log in on ptc.com.
    If i check there my license status, nothing can be found.
    I have tried it as admin and standard user and tested several keys, found in the installation pdf and here.
    Can anybody help me?
