MathCAD wont display data table
i am running a emulator on a mac for windows 7 so that i can use mathcad. before u stop reading plz help, this was the cheapest way to do it since i am in college. with that said everything seems to be working fine except for the data table function. it wont let me input a table or if a table is in a worksheet it wont recognize that there is one there. i figure that it might be something not being converted in the emulator but i was wondering if there was anyway to check that it is just on the windows 7 side and not the mac side.
    Firstly welcome to the forum.
    Can you post an example of your Mathcad worksheet and the data you are trying to insert?
    Mike
    Neville1-VisitorAuthor
    the problem is that when i click insert-data-table or right click and insert-table it just doesnt do anything. Then i tried opening a document that i did on another computer with a table in it and the table name showed up but not table. they are specific tables, just the table function doesnt work.
    I'm not sure what version of Mathcad you are running, but can you try and open the attached worksheet and tell me what you see.
    Mike
